Warnings That Should Be Fixed
Inferred Property The 'og:url' property should be explicitly provided, even if a value can be inferred from other tags.
Inferred Property The 'og:title' property should be explicitly provided, even if a value can be inferred from other tags.
Inferred Property The 'og:description' property should be explicitly provided, even if a value can be inferred from other tags.
Inferred Property The 'og:image' property should be explicitly provided, even if a value can be inferred from other tags.
However, the post with image posts fine from the actual facebook debugger share dialogue. This leads me to assume that the issue is on my site. I've spent two days trying to resolve this with no luck. It occurred to me that perhaps it was a template issue, and you might know if others have had a similar problem.
Like I say, I'm desperate, and trying every possible cause.
Thanks,
Jude
