1. roger
  3. Thursday, 22 March 2012
I was wondering how to remove the text under the slider. Thanks
In your slideshow modules parameters (Extensions -> Module Manager -> Nivo-Szaki Slider) replace the contents of the 'Images attributes' field with a single '|'
Awesome, thank you!
These errors are coming up with the slider. I also noticed the slider is not displaying all the images in the from the folder. It only shows one image. I pulled this info from Ie8, maybe help with solution.
Message: 'null' is null or not an object
Line: 87
Char: 17
Code: 0
URI: http://projectembracesa.org/templates/j51_oxygen/js/dropdown.js
Message: Object doesn't support this property or method
Line: 507
Char: 25
Code: 0
URI: http://projectembracesa.org/media/system/js/mootools-core.js
Message: 'undefined' is null or not an object
Line: 20
Char: 355
Code: 0
URI: http://projectembracesa.org/modules/mod_nivoslider/assets/jquery.nivo.slider.js
  3. # 3
May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will investigate this issue further.
  3. # 4
Thanks, I think those problem have fixed not sure. Can you run a speed test on my site and look at those errors. Its showing GET sidepanel.css error 404. thanks again.
  3. # 5
Hi Roger
To amend this issue may I suggest removing the following from the head of your templates index.php (../templates/j51_oxygen/index.php)
<link rel="stylesheet" href="/<?php echo $this->baseurl ?>/templates/<?php echo $this->template?>/css/sidepanel.css" type="text/css" />
  3. # 6
