Hi ciaran,
I have 3 questions for you, hope you dont mind.
1. I have been using the free oxygen theme (havent modified any files just custom css) but am purchasing the Oxygen theme for the support you have given me. Is it possible once purchased to remove the "Joomla Templates by Joomla51.com"? Are there any other additions to the paid version?
2. When admin/publisher and possible other accounts login to the frontend all Title's show regardless of the settings, when registered users login they are hidden as intended. This forum (http://forum.joomla.org/viewtopic.php?p=2522625) discusses the problem and a solution, they rant for a long time but the last 2 posts are the best. Although I cant implement this solution I thought it might be helpful in solving the problem.
3. the image hover's on the Home page (http://srv13.netregistry.net/~gogo1249/) are not center. Is it possible to center these inside the module position that it is located?
I have emailed you in the past and changed the admin password back so that you can access the site to have a look around it you like.
Kind regards,
Matt
