1. elmeser
  3. Wednesday, 09 May 2012
hello,
i've made a new background image for my Oxygen template.
i created a link in the jpg using the slice tool in photoshop, but when you save it, it saves the background as several images instead of one. is there any way to use several images as the background, or perhaps another way to assign a link to a small area on the background image?
thanks
Hi elmeser
You should only need to replace a single image for the background of your Oxygen template (http://demo.joomla51.com/0072/templates/j51_oxygen/images/style1/header.jpg). To export a single slice from Photoshop right click the header slice and bring to front then navigate to File -> Save For Web -> Save and from the 'Slices' dropdown select 'Selected Slices'.
