1. jsmith
  3. Tuesday, 19 March 2013
Hi there. I would like to include some custom code into webpage html body, via Joomla Template Manager / Options / Custom code / Body Custom Code. Unfortunately it looks that my code is not included into webpage. The same code inserted directly into the BODY section of ./j51_oxygen/index.php works fine. I think that the same problem could be with Head Custom Code. Custom CSS works without any problems.
thanks john and ciaran
i can confirm this fix works and that both bits of code are needed
Thank You Ciarán,
You helped me a lot but it was not the entire solution. It was necessary to also add the following lines:
//Custom head and body
$head_custom_code = $this->params->get('head_custom_code');
$body_custom_code = $this->params->get('body_custom_code');
into the ./j51_oxygen/php/variables.php
Problem solved.
Opps... sorry John.. it appears the issues is still present. Thank you for bringing this to our attention.
In your templates index.php (../templates/j51_oxygen/index.php) replace the following..
[code type=css]<?php echo ($head_tracker_code); ?>[/code]
with...
[code type=css]<?php echo ($head_custom_code); ?>[/code]
Also replace...
[code type=css]<?php echo ($body_tracker_code); ?>[/code]
with...
[code type=css]<?php echo ($body_custom_code); ?>[/code]
Hello Ciarán,
I'm afraid that the template is still not working properly. I have downloaded newest version of Oxygen from Your repository and applied it. My custom code is still not present in the BODY of webpage.
Hi John
Yes this was an issue of some of the earlier releases of this template. We hope to have resolved this problem with the latest download of the template (http://www.joomla51.com/templates/j51-oxygen-free-joomla-3-template).
