1. canwestboss
  3. Thursday, 02 May 2013
My first question is about the showcase container. Is there a way to set the alignment to centre for this position. I have my slideshow in there as well as a 'Quote of the day" module. The slideshow is ok but the other just does not look right. See http://www.selectionscareer.com/dev1
Second question has to do with the logo area. I want to decrease its height. If you look at the site there is a large amount of wasted space under the logo that would be better served showing more of the content below.
Hi Chuck
To center your 'quote of the day' try adding the following to the Custom CSS field of your templates parameters..
[code type=css]#dailyquotes div.quote {
text-align: center;
}[/code]
To reduce the height of the logo area try also adding the following..
[code type=css]#container_header {height: 155px;}
#header_items {height: 102px;}
#search {top: 110px;}[/code]
Thankyou So much.
I have one other question. I need to 'dress up' the menu modules I have in the side column postion. Things lie change the Circle arrow icon and the hove fore and back color. Can this be done.
Hi Chuck
Your menu list icon is a single image you can edit to your own taste. You will find it located at ../templates/j51_oxygen/images/bullet1.png from the root of your Joomla installation (http://demo.joomla51.com/0072/templates/j51_oxygen/images/bullet1.png).
A background color can be added to your side column modules by adding the following to the Custom CSS field of your templates parameters..
[code type=css].sidecol_block .module, .sidecol_block .module_menu {
background: #CCCCCC;
}[/code]
Where #CCCCCC is your module background color.
That is almost what I am looking for. What want to change is the text colour and the hover effect to be a different background colour on just that menu item that is being hovered. Hope this makes sense
To edit the hover state try adding the following...
[code type=css].sidecol_block .module li:hover {
}[/code]
Where #CCCCCC is your new hover state background color.
I tried the following and your part worked but mine did not. I am also trying to change the font color
background: #008000;
color:9400d3;
Hi Chuck
Ensure to add the hash sign to your hex colour (#9400d3 rather than 9400d3).
That did not work either. Also the first menu item is not the correct height. The rest are
Would you have a URL directly to an example of your sidecolumn menu?
Yes
http://selectionscareer.com/dev1/index.php/programs-services
As you can see the background change worked but the foreground (text) did not
Hi Chuck
Try changing your CSS to the following...
color:#9400d3 !important;
}[/code]
No Change
If you wish you can forward temporary administration access to your Joomla installation to [email protected] and we will make the amendments for you.
Thank you Chuck
Your menu items should now be appearing as you wish. You may have to edit the hover link color (currently set to #FFFFFF).
