Warning
JUser: :_load: Unable to load user with ID: 28543
  1. kgkoop
  3. Thursday, 22 August 2013
Hey everybody,
I'm trying to do the following:
Main Menu should have the following
Font Color #FFFFFF
Block down shoud have
background color #FFFFFF
Font Color #9a1980
Hover over color can stay the same.
Right now I can only change the color for both at the same time - that makes the sub menu unreadable.
Can you point me in the right direction please?
Best regards
Klaus
Hi Klaus
Would you have a URL to an example of your menu?
Hi Ciarán,
the original website can be found here
http://www.monikafinkbeiner dot com
As you can see the word are in black - she wants them to be white.
But as soon as there are submenus, we run into a problem. White writing, white background = zero readability :-)
So there needs to be a second color definition for the writing in the submenus - does it make more sense now?
Best regards
Klaus
Hi Klaus
Try adding the following to the end of your templates template.css (../templates/j51_oxygen/css/template.css)
#hornav ul li a {
color: #FFFFFF !important;
#hornav ul li li a {
color: #000000 !important;
Where #FFFFFF is the colour of your menu items and #000000 is the colour of your sub menu items.
  3. # 3
Thank you - that worked like a charm. I had to adjust the hover, but you showed me already the way :-D
  3. # 4
