1. KHK
  3. Thursday, 24 February 2022
Template Natalie / Joomla 3
I have some issues with this template.
I set a background image at position showcase and want to show (overlap) it to position hornav and header_top.
For this reason I set "Overlap...." in slideshow to "yes".
So far so good.
Doing this
- the image overlap only the hornav position but not the header_top position
- the function "stickyheader" is disabled, means there is no more sticky header no matter what you set
- in case of using "overlap" yes, "sticky header" yes and module position header_top1 and/or header_top2 activated, the header layout is shot
Futhermore I want to hide the line between hornav and showcase.
What am I doing wrong?
I send url and access data to [email protected]
Thanks for your assistance.
KHK
We have added the following to the Custom CSS field of of your template setting which should hopefully give you the desired results...
.header_top {
position: fixed;
#container_header, .header_main {
#container_header {
margin-top: 25px;
Hi Ciaran, thanks for your help. I have already tried the transparent background but not in the combination you suggested. I will try it tomorrow and let you know.
Regards KHK
background-color: #0000008a;
position: fixed;
width: 100%;
thanks for the quick reply. i have tried the solution you suggested, adapted it and tried it again but it doesn't really work.Especially the header_top area is not included and the transparency cuts through the logo. Maybe I didn't explain it well enough.
I did some searching and found your template "Ensley".This is almost exactly what I want. The background (also the slider background) up to the top of the page including the line with the header-1 and header-2 areas. Unfortunately I found this too late or the request came later. I will send you more information by e-mail.
Many thanks KHK
Would you have a URL to an example of your header/slideshow?
I send again my e Mail from March / 2 / 22. There you will find all data, URLs and PW.
Also you can look to your Template "Ensley" but including header_top (header-1 and header-2 Position)
Regards KHK
