1. Varelmann
  4. Tuesday, 15 August 2023
he "Overlap Header if in showcase-1# module position" of the header cannot be deactivated on the start page. All other pages are displayed correctly, only the start page causes problems.
=== J51_emani (Joomla 4) ===
https://cms-2023.bauelemente-brodt.de/
Thanks in advance for your help.
Best regards from Germany
  1. https://cms-2023.bauelemente-brodt.de
Does adding the following to the Custom CSS field of your template settings resolve the issue?...
#container_header, .sticky-wrapper {
position: relative;
If not, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
unfortunately the css code does not work. i have send you temporary access data for you.
Thank you very much
Michael
Could I ask you to allow us access to your extensions manager so we can check your template files.
i send you new access via E-Mail.
Thanks for your great support.
Michael
I have replaced the suggested CSS with the following which does the trick...
body .outside_header .sticky-wrapper {
position: relative;
thank you very much, it works.
Can you tell me how to change the background colour of "home" - it's just FFFFF, but I want to change it to the same colour as the other pages.
Michael
Hi Michael
Presuming I understand you correctly, try adding the following to your custom CSS field (edit to taste)..
.hornav .item-101 a {
background: red;
padding: 10px !important;
I apologise very much. I had not expressed myself clearly. It is about the background colour for Header Main Background Color. The colour is the same on all pages - just not on the homepage.
Thank you very much for the great support.
Michael
Hi Michael
Ah my apologies. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
(edit to taste)
#container_header {
background: #ececec;
