1. z0r0z
  2. Love Fool Vanity Monster Sherlock Holmes
  4. Friday, 21 October 2022
Dear Ciaran,
How can I set the overlap headers in the showcase1a module with another slider (Smart Slider 3)? Or does it only work with the J51_LayerSlideshow module?
Thanks for the help
Best regards
Marcel
Hi Marcel
Would you have URL to an example of your slider?
i use this Slider: https://smartslider3.com/
Best regards
Apologies as I should have been more clear. Do you have a URL to an example of your slider within your template?
Thank you for your help.
Best regards
#container_header-sticky-wrapper {
position: absolute;
width: 100%;
Okay, that worked before, when scrolling down the header background should be white again, like on the start page.
