I'm not sure if this is any Jasmine issue (and is this forum right place to ask, but I'll give a try
 )I want to have OpenStreetMap viewed in my template using sticky header. I've tried OsModule and Phoca Maps extensions, the behaviour is the same: the map image goes "over" the header while the module title goes "under" (see screenshot). All other content on the page works as expected (->goes "under"
.I couldn't have found the solution myself (which is hopefully some simple css), so I turn to you. Can you help?
Best regards, Reino
