1. Mol4
  4. Friday, 19 April 2019
Sorry if I ask this twice, I can't find my earlier question in the forum.
On my testwebsite I use the One Page Navigation.
On desktop all is working fine.
Only on mobile the IDSA link doesn't scroll down.
I can't figure out why.
Can you please point me in the right direction?
Thanks!
Great!
Thanks again for your great work :D
Greetings,
Ton
Have you since amended this issue? The ISDA link appears to scroll to on mobile without issue (Android).
No, it doesn't work yet. I'm using an iPhone 7.
Thanks!
On what screensize are you having this issue? I notice below 767px, your base1 module block is hidden.
Yes, now I see you're right!
But I can't figure out why this is.
I've no custom css for the base modules and in the template responsive options the base modules are not hidden also.
Only thing is that the base-1b module has the module class 'hidden-phone'.
The base-1a module doesn't have this so then it's strange this is also hidden.
I use the class 'hidden-phone' in the same way with the other positions.
Maybe you can have a look?
Thanks!
This turned out to be a template issue which we have now amended with the latest template update. We have installed the update and your base modules are now displaying correctly on small screen devices.
