1. Turbomay
  4. Tuesday, 21 April 2020
how can I replace the comma with a dot in the "numbers module". Example from 75,000 to 75.000
Thank you very much, Frank
Hi Frank
We are currently working on an update for this module which will include the option to set the comma to the symbol of your choice. I hope to have this available in the next couple of days. I will ping you here once available.
We have just updated the J51 Numbers module. This update includes the addition of options to enable/disable grouping and set grouping and decimal separator character. To obtain the latest download navigate to Profile -> Extension Downloads.
outstanding... thank you so much.
Frank
Sorry Ciaran,
unfortunately it does not count up! It only shows the desired number !!!!
Frank
Hi Frank
My apologies. There was a slight issue with the build script. All should be ok now (just updated)?
Note that after install, open your module settings and save.
now it is working fine. :)
Thanks, Frank
