1. Iankellett
  3. Monday, 17 March 2014
Is there a way of increasing the number of images allowed in the grid gallery in Renovate please? I saw another post with the same question but was unable to fired
$max_images =
http://www.solwacraft.co.uk/home
Sorry to say at present our GridGallery extension can only display up 15 images. This is restricted by the number of fields set in the templates parameters. To edit this you will have to repeat the following in your modules mod_j51gridgallery.xml..
<fieldset name="IMAGES_15">
<field name="j51_image15" type="media" default="" label="MOD_J51_IMAGEPATH" description="MOD_J51_IMAGEPATH_DESC" size="30" />
<field name="j51_image_alt15" type="text" size="60" default="" label="MOD_J51_IMAGEALT" description="MOD_J51_IMAGEALT_DESC" />
<field name="j51_title15" type="text" size="60" default="" label="MOD_J51_IMAGETITLE" description="MOD_J51_IMAGETITLE_DESC" />
<field name="j51_text15" type="textarea" filter="raw" rows="4" cols="42" default="" label="MOD_J51_IMAGETEXT" description="MOD_J51_IMAGETEXT_DESC" />
<field name="j51_disablecaption15" type="radio" default="no" label="MOD_J51_DISABLECAPTION" description="MOD_J51_DISABLECAPTION_DESC"
checked="checked"
class="btn-group">
<option value="no">JNO</option>
<option value="yes">JYES</option>
</field>
<field name="image_url15" type="menuitem" default="45" label="MOD_J51_MENUITEM" description="MOD_J51_MENUITEM_DESC" published="1"/>
<field name="j51_disableurl15" type="radio" default="no" label="MOD_J51_DISABLEURL" description="MOD_J51_DISABLEURL_DESC"
checked="checked"
class="btn-group">
</field>
<field name="target_url15" type="radio" default="_self" label="MOD_J51_URLTARGET" description="MOD_J51_URLTARGET_DESC"
checked="checked"
class="btn-group">
<option value="_self">JNO</option>
<option value="_blank">JYES</option>
</field>
</fieldset>
For each repeat of this you will have to increase the digit by one..
eg..
<fieldset name="IMAGES_16">
<field name="j51_image16" type="media" default="" label="MOD_J51_IMAGEPATH" description="MOD_J51_IMAGEPATH_DESC" size="30" />
<field name="j51_image_alt16" type="text" size="60" default="" label="MOD_J51_IMAGEALT" description="MOD_J51_IMAGEALT_DESC" />
<field name="j51_title16" type="text" size="60" default="" label="MOD_J51_IMAGETITLE" description="MOD_J51_IMAGETITLE_DESC" />
<field name="j51_text16" type="textarea" filter="raw" rows="4" cols="42" default="" label="MOD_J51_IMAGETEXT" description="MOD_J51_IMAGETEXT_DESC" />
<field name="j51_disablecaption16" type="radio" default="no" label="MOD_J51_DISABLECAPTION" description="MOD_J51_DISABLECAPTION_DESC"
checked="checked"
class="btn-group">
</field>
<field name="image_url16" type="menuitem" default="45" label="MOD_J51_MENUITEM" description="MOD_J51_MENUITEM_DESC" published="1"/>
<field name="j51_disableurl16" type="radio" default="no" label="MOD_J51_DISABLEURL" description="MOD_J51_DISABLEURL_DESC"
checked="checked"
class="btn-group">
</field>
<field name="target_url16" type="radio" default="_self" label="MOD_J51_URLTARGET" description="MOD_J51_URLTARGET_DESC"
checked="checked"
class="btn-group">
</field>
</fieldset>
Thank you for the response.
From this I suspect there is a good reason for the number of images to be limited to 15, so I will re-arrange around that number.
