Hi there,
I am upgrading my client's website from 2.5 to 3.3, they want to keep the same template.
The site uses an extensive amount of blockquotes and once I installed the new version for 3.3, the blockquotes don't appeat to line up correctly. It appears that the blockquote on the left side isn't coded correctly. I took at look at the 2.5 coding and it seems different than the new template. Is there something I can do to get the blockquote to line up correctly? I have attached a screen print to show you my issue.
