1. louies
  3. Tuesday, 07 August 2012
How to I create a registration page on my recently purchased novation template?
Yes we can have a quick look for you.
Could you check the URL sent as we appear to be getting a 404 error.
Thanks. Will do that. And also, I'm encountering error on my website. Is it possible for you to check it also?
Strange..
Wouldn't be template related but if you wish you can send temporary adminitration access to your Joomla installation to info@joomla51.com and we will have a look for you.
Thanks for the reply!
Already did that but is shows as a log in page.
Hi louies
In Joomla to create a menu item to a registration page navigate to Menus -> [YourMenu] -> New. In the 'Menu Item Type' field select 'Registration Form'.
