1. jascanio
  4. Wednesday, 24 February 2021
I'm using Novah 1.0.9
Because when articles' images for Intro and Full Content are inserted from the "Images and Links" tab, text won't wrap the image, I've applied the solution recommended in the post included below, at the url field.
This means renaming template's ../html/com_content to anything, in order to disable it.
However, by doing so, I lose the Category Blog - Alternative and Category Blog - Masonry options in the menu. Furthermore, if I install an updated version of the template, I will have a new com_content again.
Is there any other way to proceed which I can apply?
Thanks in advance for your reply.
Regards,
Juan
  1. https://joomla51.com/forum/sophia-text-won-t-wrap-image-if-set-from-images-and-links-tab-in-articles
Hi Juan
Looks perfect from here! Nice work :)
Hi Juan
Rather than renaming the entire override directory,you can remove the specific overrides for the default view while keeping the overrides for the masonry and alternative view. To do so delete the following two files...
(back up first :) )
../templates/j51_novah/html/com_content/category/blog.php
../templates/j51_novah/html/com_content/category/blog_item.php
Thanks for your reply.
I tried your recommendation, but this didn't solve the issue, so I kept researching around.
I found out that when article info (published date in may case) is set to be displayed, text won't wrap image.
If I disable this option, then I get the images wraped by article's text. But I need the published dates displayed for my News section of the web.
An interesting point is that if I set article info to be displayed below the article, images are wrapped correctly.
Can you think of any solution?
Thanks in advance for your help.
Regards,
Juan
PS.: Just edited template's custom css to substitute display: inline-block by display: inline for artcile info class, but I don't know whether this will have any side effects.
article-info {
display: inline;}
Hi Juan
If this is still an issue, could you provide a URL to an example of your blog?
What I did is a sort of patch. I don't know whether it is a solid solution. Although text finally wraps images, I don't know whether this is the best way to go around.
I've added link to my blog in the url field bellow.
Thanks,
Juan
  1. http://tecnico-cp571.webjoomla.es/actualidad/noticias
Ok, thanks for your reply.
Regards,
Juan
