1. hvdmeer
  3. Wednesday, 02 March 2022
I noticed whenever a link is in the intro text it results in incorrect working of the article info. The link is not visible in this screenshot, it was after the cut off but still before the Read more code. I use the Masonry layout here.
I solved this by removing the link from the intro text. Is this a bug in the template?
Thank you Ciarán, I leave this in your capable hands what's best. I now know I need to watch out with links in the intro.
THank you for reporting. May I ask on which Joomla version are you finding this issue?
Hey Ciarán, the site is now on 3.10.6 but it also happened in previous versions
The issue is likely due to the caption text being cut halfway through a link, where the caption includes the opening anchor tag but not the closing anchor tag. A solution to amend this issue would be for us to strip all HTML from the caption text. There is a downside to this where some users wish to display other HTML within the caption (eg. bold, italic, headings etc.).
