hi, I had the same problem indicated in this post ( https://joomla51.com/forum/novah-double-page-heading ) and tried to solve it in the same way, but the titles of the articles disappear too (see attached images).
How can I solve it?
Thanks in advance
- maurilla
- Wednesday, 26 October 2022
Hi rebelojose,
the contact form I used is not part of template, but is a third party extension.
You can find it on the jed page.
hi,
how to remove header(above) from Blog Classic (view image) ?
and another question if it is possible, how put contacts like show in this site from user Maurilla labbracciodiedo.org
in full width?
tks in advance
in full width?
tks in advance
Hi.
Unfortunately it doesn't work.
As you can see, if I don't display the heading title, also the titles of the articles disappear.
https://www.labbracciodiedo.org/index.php/progetti-3
This hidden link is another example with other template settings
https://www.labbracciodiedo.org/index.php/progetti-2
However it is not a big deal. As I said, I would have preferred the title placed under the main menu, but it's fine without it too.
Does adding the following to the Custom CSS field of your template settings give you the desired result? This will hide the second page heading in your screenshot...
.maincontent .page-header {
display: none;
}Ciaran
Hi ciaran.
This is the site
Now I have removed the page heading directly from the menu settings. I preferred it with the title under the main menu, but that's okay too.
Note that even the display of the articles has some problems, as well as the image hover module which in masonry mode had big alignment problems, but I solved this issue by reinstalling a version of it for another template J4 I had previously purchased and now it's ok.
This is the site
