1. Hammur
  4. Wednesday, 22 April 2020
Hi, I'm having an odd issue with the article edit page using the Novah template on a site I'm currently building.
1. When opening an article on frontend and selecting edit from blue tool dropdown, the edit page opens with a shaded overlay that however includes close button to close it. While it's not directly an issue, it is a bit annoying and don't know what is prompting this overlay, if it is a setting somewhere or not?
2. Next thing is that at the bottom or kinda in between the footer area and the main area there seems to be a svg container blocking contents in the main area i.e. the buttons below the editor, e.g.save and cancel button! (Content in the footer area is not blocked by this svg container)
See also attached screenshots.
This svg container seems to be generated in the file .../templates/j51_novah/inc/layouts/base.php line 15. Don't know what the purpose of it is or if it simply can be removed?
I did not experience the 1. issue with the demo of Novah that I have installed on a test site so not sure if there is a special case or setting which prompts this overlay behaviour when opening the edit page of an article? (I only get this when using the J51_Novah template, not if I example change to protostar)
Regarding the svg container, it is also there on the Novah demo, but located just below the Save & Cancel button so not really causing any trouble, not sure why this is different.
Attachments (3)
