I have the top menu active/hover colour set to #664970 which is the same colour I have the button colour set to in the module below the slider yet they look totally different. Is there some sort of gradient on the active/hover colour on the top menu as it looks less vibrant and more grey than the button colour? How can I change this please?
Also, is there a gradient in the background colour? It doesn't appear to be the same colour as my background colour in the copyright section although they are both set to #1B0A2A. If so how can I remove the gradient on the background colour please?
