1. JoomlaGirl
  4. Wednesday, 12 June 2013
Thank you for your very prompt reply on my question yesterday. I have another couple of issues:
1.I have the 'body font colour' set to #DDDCED so that is shows up nicely on the home page and articles etc. The issue arises in both VirtueMart and another module RS Monials as they have light backgrounds and the text is thus not readable. What is the workaround for this please?
2.Is there a way to place the buttons and button text above the photos in the 'Image Link Hover Module by Joomla51'?
3.Where can I reduce the height of module p 'Header Text'?
Thank you Kirsty... much appreciated :)
I believe bestofjoomla have to publish reviews before they can be viewed.
Thank you once again. I posted a customer review for you on Best of Joomla, although it doesn't seem to be showing up yet.
Thank you Kirsty
I have updated your extension with the suggested changes and it now appears to be showing as requested.
Hi Kirsty
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email
Sorry every time I include attachments whether they be jpg or png they are deleted once the reply is posted. The link to the after result is
Thank you once again for your assistance, your advice solved issues 1 and 3. Unfortunately with issue #2 I inserted the test into mod_j51imgaelinkhover.php and it has not resolved the issue. I have attached a before and after screenshot to show you what I mean.
I would appreciate any further advice you may have.
Kirsty
Hi Kirsty
Presuming you want to remove the space under the text 'Welcome to Gifts from Gaia' is there a reason for having the empty paragraph (<p></p>;) just after it? Removing this paragraph will remove the space.
Thank you here is the link to the example for question 3, it's the container that has the text 'Welcome to.....' directly under the slider :)
I will try your solutions in the morning and let you know how I go, many thanks for your excellent service.
Hi Kirsty
1. For your Virtuemart modules try adding the following to the Custom CSS field of your templates parameters...
[code type=css].yagVmCategoryView, div#yagVmOverWrap {color: #000000;}[/code]
For RS Modials try adding the following...
[code type=css].RSWS_testimonial {color: #000000;}[/code]
2. In your modules mod_j51imgaelinkhover.php (../modules/mod_j51imgaelinkhover/mod_j51imgaelinkhover.php) try replacing the following...
<div class="j51imagelinkhover">
<div class="j51imagelinkhover<?php echo $j51_moduleid; ?>" >
<div class="j51imagelinkhover_border">
<div class="j51container effect" style="background-image: url("/<?php echo $j51_image; ?>")";>
<div class="mask">
<a href="/<?php echo JRoute::_("index.php?Itemid={$hover_link}") ?>" class="info" >Image Link</a>
</div>
</div>
</div>
</div>
<?php if($j51_title != "") : ?>
<h3><?php echo $j51_title; ?></h3>
<?php endif; ?>
<?php if($j51_text != "") : ?>
<p><?php echo $j51_text; ?></p>
<?php endif; ?>
<?php if($j51_buttontext != "") : ?>
<div class="j51button"><a href="/<?php echo JRoute::_("index.php?Itemid={$hover_link}") ?>" class="info" ><?php echo $j51_buttontext; ?></a></div>
<?php endif; ?>
</div>
With...
<?php endif; ?>
<?php endif; ?>
<?php endif; ?>
</div>
<div style="height:35px;"></div>
<div class="mask">
</div>
</div>
</div>
</div>
3. Would you have a URL to an example of this module p?
