1. pedra
  4. Friday, 19 July 2024
I need your help again. This time for the Nina-Template (runs on Joomla 5/ PHP 8.1).
How can I design the top menu and the dropdown menu like in the example?
Thank you in advance for your hints.
  1. https://www.tebogmbh.de
Presuming I understand you correctly, I am sorry to say, there is only a single default display for the top menu as demonstrated on the template demo.. https://www.joomla51.com/demo/0173/
Sorry, I probably formulated that too imprecisely.
My idea was to rebuild the menu in the Nina template according to the example page.
I was able to easily implement the light/partially transparent background with the template.
- Now I need a blue button with white font for the menu items, if the meter item is for hover and if it is active.
- The arrows to indicate that there are other meters below are not automatically displayed.
- But I would have liked them to be arranged on the right side or even better that they are displayed automatically.
- In the drop-down menu, the menu item disappears at hovern. Assuming that this is controlled by the primary color, I changed the color - without success.
- I would add the whole thing to the Custom.css if you have a suggestion for me.
Attached is the link to the current status.
Thank you and greetings Pedra
