1. hatchikian
  3. Friday, 23 June 2023
I have added the following code to my custom css, following an idea found in the forum
/*couleurs de fond du logo en hexadécimal container_header*/
#container_header {
background-color: #721e1e;
Works fine, till I adjust the style of the template to "sticky header"
If I scroll down the page, the background-color instantly changes to black.( in fact to #273233 )
What did I miss?
Regards,
Jean-Pierre
  1. https://www.hatchikian.fr/
Sorry for the inconvenience
I use this domain as a sandbox, so it is constantly on and off.
Regarding your reply : it works.
Thanks,
Jean-Pierre
Hi Jean-Pierre
Your site appears to be currently offline.
Looking at your CSS, you should get the same result if you edit the header background color option in your template style settings?
