1. nigelk
  3. Monday, 21 April 2025
I'm using Nina 4 and seem to have a problem with the menu width.
There does not appear to be enough horizontal room for the menu as I can only get 7 menu headings where I need about 8 or 9. The others just get truncated off the RHS of the page.
I think that part of the problem is that the logos and menu are in the same section as opposed to earlier templates where the logos and menus where in separate sections (if that makes sense) is there any way around this with some custom code ?
thank you,
regards,
Nigel.
the developer definitely needs a link to your site
No one knows what and how you might have changed or installed it.
As mentioned, if your provide a URL to your site, we could then provide some custom CSS to style your menu to better accommodate it's items.
I was able to expand the menu by reducing the size of the logo image, unfortunately the menu still is not wide enough and the Logo is now looking too small.
here are two urls,
The first one is the current website as done using an earlier template. and the second url is the upgrade of the website to the Nina template.
current website: https://www.oceaniadancesportchampionship.com.au/
Nina website: https://dance4.oceaniadancesportchampionship.com.au/
regards,
nigel.
Hi Nigel
(Edit to taste)
.logo-image.primary-logo-image {
max-width: 300px;
.hornav ul.menu>li>a, .hornav ul.menu>li>span {
font-size: 16px;
letter-spacing: 0;
.hornav ul.menu .parent-indicator {
margin-left: 0;
Thank you for the CSS code. It works very well.
However now I have a problem that the background image disappears when you select a sub menu item.
It only happens on sub menus, do you happen to have a fix for this please ?
regards,
Nigel.
Hi Nigel
Have you created multiple styles of your template? If yes, could you try reselected the background image on the style for your sub menu items. The currently selected images appears to give a 404 error.
If this does not resolve the issue, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
Hi Nigel
I have not created multiple styles of the template, although I do have a copy in case something goes horribly wrong.
I dont seem to be able to locate where the "bg image for sub menu" is located.
Thus I have forwarded admin login details to you as requested.
regards,
Nigel.
Do you have any progress on my sub menu problem.
I have forwarded admin login to the website via email as requested.
regards,
Nigel.
This issue should be now resolved. To amend I have updated the URL in your Custom CSS to include the full URL to the image. Note you will have to update this URL if you move your site to another domain.
.body_bg {
background-image: url(https://dance4.oceaniadancesportchampionship.com.au/images/bg/ODSC_website_skin_2000w.png);
background-attachment: scroll;
background-size: contain;
Thank you for the Fix It now works perfectly, again thank you.
However there is one last issue which I cannot seem to rectify.
When viewing the website on a mobile phone the column it creates seems to be narrower than the phone display.
you can when swipe the display and see the background where its about 1/3 of the width of the page.
I would assume when viewed on a mobile phone the modules would fill the complete width only.
regards,
Nigel.
Can you please look at my mobile rendering problem. There appears to be a "small gap" on the RHS of the page when viewing on a mobile phone.
regards,
Nigel.
Hi Nigel
I am not sure if I understand you correctly. Could you please detail what you mean by RHS?
When viewing the website on a mobile phone the viewing column appears to be narrower that phone because if you "swipe"
the page to the left then there appears to be part of the website outside of the viewing column on
the far right hand side of the page, Its only about 1/4 inch but its there on every page.
I've fiddled around with page widths etc but it seems to have no effect on the problem.
regards,
Nigel.
