1.) The read more button doesn´t contain text
(as you can see in the attached screenshot)
When I switch to Cassiopeia it works fine as it should
2.) Fixed header in template settings doesn´t work.
css doesn´t work either: #container_header {position: sticky; top: 0; z-index: 10;}
3.) Coyright
Entering a link to an extern website does not work because the base url is prepended
Please support! thanks
