1. b8fish
  3. Saturday, 15 July 2023
My image in a module in position Showcase-1a is rendered overlapping the header container.
This is also true for modules in the Top-1 position if there is no Showcase-1 module
Attached are screenshots showing the area as displayed and the area as identified by Chrome inspect
This also overlaps if sticky header is on or off
Suggestions?
See j4.bigwoodsgoods.com
Paul
  1. https://j4.bigwoodsgoods.com/
Hi Paul
It was actually a Custom HTML module, not a SlideShow module. I did try creating a slideshow module and disabling the overlap option which did indeed drop the image below the header but still overlapped the social media icon bar. I added some empty lines into the "HTML before" field which dropped it down below the social media line. However, as a slideshow module, the pic is auto-zoomed indefinitely as it is a single image - which is not an effect I want to see on that module.
So, I went back to Custom html module and added a margin-top:5em to the image.
That is at least giving me the correct visuals for this showcase module -- j4.bigwoodsgoods.com
Other pages do not have the showcase position and do have a slideshow module with multiple slides and so the auto-zoom effect is appropriate.
However, is there a way to manage the image animation? All I see is title and caption animation controls.
about the zoom-in animation effect in the layerslideshow module: I used the Nina template on this page too: https://weberhof-aschbach.de/
We disabled the animation effect by adding the following to our custom.css:
div.layerslideshow .tns-slider img {
transform: none !important;
Hope this helps.
Oliver
