1. pschmili
  4. Wednesday, 24 November 2021
Hallo
Is there any possibility in the "J51_LayerSlideshow"
to format the "Slide Title" and the "Slide Caption" (line break)? insert Html-code if necessary?
Greetings
Peter
Hi Peter
Does the following resolve the issue for you?.. https://docs.joomla.org/Entering_raw_HTML_in_editors
Hallo
Unfortunately no. In the "J51_LayerSlideShow module" no formatted text can be entered in the "Slide Caption", no matter with which editor, or without editor.
Greetings
Peter
Hi Peter
Thank you for the update.
To amend try installing the attached LayerSlideshow update which should allow you to set safe HTML in the caption field..
Hallo
Thank you, this is exactly what I was looking for.
Greetings
Peter
