1. pschmili
  4. Thursday, 11 November 2021
HI
What can I do to hide the two header modules in the NINA (J4) template also on the desktop display (as possible in the mobile display)?
Greetings
Peter
Hi Peter
I am not sure if I understand you correctly. Do you wish to display these modules on mobile but hide them on desktop?
I don't want to display the two header modules on desktop or mobile
Peter
Hi Peter
You can then simply disable/unpublish the module via your Module Manager. Note you can filter the module manager table by position to help find the correct modules.
