MENU
  1. ColDee
  4. Sunday, 01 May 2022
I can see the settings for modules, but there are no settings for Footer 1 and Footer 2.
Can you let me know where to edit these please.
Regards,
Colin.
Hi Colin
Would you have a URL to an example of your modules?
I'm just working on it now: http://hansglobalsecurity-com.stackstaging.com
Regards,
Colin.
Thank you Colin
Amending the background color of your base-2 module block via your template style settings should also affect the footer-# position backgrounds?
How can this be when the footer position and the footer 2 positions clearly have different background colours?
Also, base-2 and footer background colours are both set the same by default in the demo installer?
Regards,
Colin.
I've managed to sort it with the following custom CSS:
.jarallax {
background-color: #002137;
I think the option should be included in the template parameters though?
Regards,
Colin.
