Edit:
It is of course annoying if you buy a template for J4 and then realise during the Quickstart installation that it is already running on version J5. Is it not possible to indicate this in the template description? The extensions I bought are intended for J4. There is only a beta version for J5. Dear Ciaran: Can you please write the correct Joomla version in the templates when you sell them? Then this can no longer happen.
Hi all,
I use the NINA template. I have purchased "Media-Tools" from DJ-Extensions. Unfortunately there is an error message:
"An error has occurred. 0 Class "JFactory" not found"
Is this a compatibility problem?
How can I fix the error? Or do I have to contact DJ-Extensions?
I hope someone can help? Thank you very much
Tina
