1. DamsStChristophe
  3. Sunday, 27 November 2022
Hi Ciaran.
I am having a problem with the Nina template.
I started with a new Joomla installation, then Nina j51_nina_j4.zip (Joomla! 4.x Install Files), then I created everything I needed too and it seems to work ok.
I then installed RS Firewall and that's when I started having some issues like that message on every pages of the site :
"Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in /home/******/*******/templates/j51_nina/html/layouts/chromes/mod_standard.php on line 18",
and those in the back office :
"Deprecated
: reset(): Calling reset() on an object is deprecated in
/home/******/*******/templates/j51_nina/elements/googlefonts.php
on line
256"
After searching for a cause/solution, I downloaded and installed the latest version of the template which solved part of the issues.
The message on the pages of the site disappeared, but the ones in the back office are still there (only in the "general" tab.
I also noticed that the space taken by "component" seems to be bigger (in height).
Could it be the case?
Is there a way to reduced the height of "component" when it is left empty?
And, I also noticed an icon who appeared on the site (front end) with the Joomla logo, which displays informations about Joomla and the template when I click on it (PHP debug bar).
Is that something that can be disabled?
Kind regards.
Damien.
Hi Ciaran.
I "solved" my problems by remembering that I edited the" configuration.php" to "debug" as I had something weird happening after I installed RS Firewall.
So, setting it back to normal "fixed" the issues.
Will try to remember it next time.
Sorry.
Kind regards.
Damien.
Hi Damien
That is good to know. Thank you for updating me on this issue.
