I installed the NINA demo but It gave an error
Error
"Duplicate entry '700-5.3.0-2025-03-14' for key 'PRIMARY'"
The site is there - but I cannot enter as administrator as the username/password I entered does not work
Warning
"Username and password do not match or you do not have an account yet."
Any fixes are more than welcome.
In Nina QuickStart, an SQL file is executed during the import process, inserting a duplicate entry into #__schemas, thus creating an existing entry. This causes the import to fail with a duplicate key error.
The affected file in the QuickStart package is:
It contains (around line 1895 in my case) the following statement:
The part (700,'5.3.0-2025-03-14') is the culprit.
Solution: In the file installation/sql/mysql/custom.sql, remove the entry for 700:
Before:
After:
Then reinstall QuickStart (ideally with a completely empty/new database), and the installation should complete successfully.
Best regards
INSERT INTO `#__schemas` VALUES (21,'5.0.0-2023-09-11'),(700,'5.3.0-2025-03-14'),(1254,'3.5.1');
Before:
After:
INSERT INTO `#__schemas` VALUES (21,'5.0.0-2023-09-11'),(1254,'3.5.1');
Best regards
Hi Ed,
in this Nina Quickstart guide, the error is specifically located in the file:
The relevant line in your package is 2441:
The primary key of this table is (user_id, group_id) – and (443,8) already exists in your import → hence the "duplicate entry '443-8'".
Change line 2441 from:
Regarding:
This ensures duplicate mappings are skipped and the import runs smoothly.
Best regards
INSERT INTO `#__user_usergroup_map` VALUES (...,(443,8),...);
INSERT INTO `#__user_usergroup_map` VALUES (3,8),...,(443,8),...,(992,8);
Regarding:
INSERT IGNORE INTO `#__user_usergroup_map` VALUES (3,8),...,(443,8),...,(992,8);
Best regards
- 2 weeks ago
Hi z0r0z,
I bought Nina a few days ago and encountered the same issue so I followed your instruction.
I have change line 1895 into
But now I am getting error "Duplicate entry '443-8' for key 'PRIMARY'" in a new database (PHP 8.3.30).
Any suggestions?
Best regards
Ed
Any suggestions?
Best regards
Ed
- 2 weeks ago
- # 14
