1. andman
  3. Wednesday, 03 April 2024
I'm using the template "NINA".
How can I change the color of the title on mobile menu (e. g. the word "MENU" at the highest level)?
Best regards.
Andreas
Hi Andreas
Replace me with the text you want to insert...To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.mm-spn.mm-spn--navbar:after {
color: #ffffff;
Edit to taste
fine, that works.
But the title still seems a little bit pale.
Do I have to unset some proporties (e. g. tranparency or shadow)?
Andreas
Hi Andreas
Try amending your custom CSS with the following...
color: #ffffff;
opacity: 1;
Thanks, that's it. :-)
