1. [email protected]
  3. Wednesday, 10 November 2021
NINA template. Joomla V3. The breadcrumb shows the path, (i.e. Home -> Information -> Videos Nominees -> Nominees 2012) however only «Home» is a link. The further elements of the path are no links. How can I correct this?
HI Rolf
Thank you Rolf
We have been looking into this issue and strangely when we bypass all influence the template has on the breadcrumbs module, the issue is still present. We also noticed that the issue is also present on the default Joomla template (Protostar). We will continue to try and replicate this locally and hopefully find the source of the issue.
thx for your reply. Seems to be a Joomla problem. I'll be patient and await the result of your research.
What about my other post? see: https://www.joomla51.com/forum/bug-in-nina-template
Rolf
what is the outcome of your investigation?
regards
Rolf
HI Rolf
We did attempt further to try a replicate the issue in a local environment but unfortunately did not have any luck. The issue appears to be specific to your installation. Have you any content plugins installed that may effect how your breadcrumbs is been rendered?
I have the same problem!
I have tried different medias. Foir me it is just on the I-pad (when I have it so the ordinary manue is showed).. Home and the login menues work but not the rest.
/Hans
I've tested breadcrumbs with Emani-J4-v102 and with Nina-J4-v105 and breadcrumbs work fine here with both templates.
There is perhaps one point worth mentioning and this may look silly: menu items of type menu heading logically have no link. If a submenu item below is the last one (and set to appear), then there is no link here either, so only home has a link.
This will look like this: You are here: Home (with link) - Test1 (type menu header, no link) - Test2 (sub, no link because of last item). It then seems as if the croadcrumps don't work, because only Home has a link.
If there are one or more submenu items below the submenu item (i.e. one or more levels deeper), it might look like this:
You are here: Home (with link) - Test1 (type menu header, no link) - Test2 (sub, with link) - Test3 (subsub, no link because of last item) and so links appear at Home and at Test2 .
Sounds crazy, I know, but worth a try?
