1. nigelk
  3. Wednesday, 16 April 2025
Is it possible to add an image to the body background of NINA. There does not seem to be an option as in other templates.
Sorry to say this option is not available with out Nina template.
I'm using a NINA template
You could try setting the transparency of each module block background to 0 and add the following to the Custom CSS field...
(edit to taste)..
.body_bg {
background-image: url(#);
background-attachment: fixed;
background-size: cover;
Replace # with the url to your image.
Thank you for the response. I added the code to the custom CSS and changed the transparency of the modules and it worked OK.
However, where I have a drop down menu the background works ok on the parent menu but when I select the drop down menu the bg image disappears.
When I then select another parent menu the bg image re-appears.
Can you please advise what may be done to correct this
regards,
Nigel.
