1. Amorati
  3. Saturday, 18 October 2025
after upgrading to Joomla 6 I can't edit the style of Nina.
I bought and dowloaded again Nina but it doesn't work.
Hello Amorati,
Can you give me some information about your website?
- is the website running the Joomla Core template (Cassiopeia)?
- have you installed or updated any Joomla 51 modules or extensions?
- what is your PHP/server version?
- have you activated the BC (Backward Compatibility) plugin?
EDIT: For me, the Joomla51 Emani template only works under Joomla 6 if the Behavior – Backward Compatibility 6 plugin is activated.
Best regards
Problem solved after activating the Behaviour-Backward plugin.
Thanks and best regards
Great to hear that the issue is solved! Thanks for the update.
Best regards
