1. astridg
  3. Sunday, 16 January 2022
I tried https://www.jevents.net/ with Nina.
1. I have installed Joomla 4 and integrated a JEvent calendar via menu manager.
2. under Cassiopeia the calendar was displayed without errors.
3. with nina the view was broken. Among other things, the scripts and styles in the header were not set correctly.
4. first I commented out the line <?php require("inc/layouts/main.php";); ?> in the file j4/templates/j51_nina/index.php. Result: No more errors, but of course no calendar either.
5. I undid the change from 4. and only removed <?php if ($this->getBuffer( 'message' )) : ?> and <?php endif; ?> around <jdoc:include type="message" /> in the file j4/templates/j51_nina/inc/layouts/main.php. So
instead of
<?php endif; ?>
in the file j4/templates/j51_nina/inc/layouts/main.php. This solved my problem at first sight.
6. what getBuffert does can be seen in the file j4/libraries/src/Document/HtmlDocument.php in line 542. But I have stopped here now, because I am sure you know better where the problem lies and how it can be solved.
hello astridg
Exactly the same error as with my problem!
Link here in the forum...
I followed your instructions and the error is gone for now. Maybe @ciaran can say more about it!
Thank you for sharing your solution :)
We have just updated the Nina template, removing the getBuffer condition from the component message. It appears getBuffer is no longer available in Joomla 4, something we completely missed when updating the template.
Good work!
and what about the other J4 templates, especially for me with Layla?
We have just updated the Layla template also.
Hi.
I updated the template (Layla) today BUT the ERROR IS BACK...
If I repeat astrid's procedure in main.php, the error is gone again...
Something is wrong with the template update?!
In the settings is still version 1.0.3
I've tried several times
We have tested the template download and are no longer able to replicate this issue. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
I've just sent an email to [email protected]
I asked "astridg" from the thread, their template "nina" no longer has the error.
In the Layla template, the code that causes the error still exists...
I currently have version 1.0.5 installed BUT I manually deleted the faulty code from the file: j4/templates/j51_nina/inc/layouts/main.php
Could you please also send details for the htaccess protection on your administration folder.
Excuse me. I forgot to protect administrator access. I am very sorry!!! I sent now the data via email!!
Thank you @eumel7
I have updated your template from version 1.0.3 to 1.0.5. The change kindly suggested by Astrid should be now available to you.
Dear Ciaran,
if I understand eumel7 correctly, than you missed the deletion of the lines
<?php endif; ?>
in the file
of the Layla template. In the newest version of the Layla template the code
<?php endif; ?>
is still in the file
This causes an error in his website, too. Like in my case with NIna, wich is already fixed.
Could you please check the latest version of the Layla template ?
The template has now been updated. I downloaded / updated the template again with the new file and it works great!
thank you
