1. ragal51
  3. Monday, 28 December 2020
1) I am using the News Module and I am wondering if it is possible to have a few defined lines of the article instead of characters.
I want to tell the news module to display the first 2 or 3 lines of the article.
2) Why is the news module ignoring the line breakes? How can I tell the module not to ignor the line breaks? "</br>
Ragal
The display of formatted text is a problem I also encounter. Can you explain the solution?
Hi Regal
We have created an override for your module allowing you to display formatted text. Note that some html element can not be truncated without breaking the layout, in particular tables. I have disabled articles with tables in the summary area of the article.
Hi Regal
.j51news-caption {
display: -webkit-box;
-webkit-line-clamp: 3;
-webkit-box-orient: vertical;
overflow: hidden;
Edit to taste where 3 is the maximum number of lines to display.
2. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
