1. marcusadamski
  4. Sunday, 22 December 2019
I've started to use the News Module, but stumbled on an early issue. I only intend to display the latest news article on the home page, but I cannot find a suitable configuration which will work for both desktop and mobiles. If set to one column and the item layout to "Row - Text|Image" - this displays fine for desktop fine, but for smaller mobile screens (portrait) displaying text and an image side by side is far too cramped. However, if I use the item layout to "Column - Image|Text", the smaller article image is used and therefore pixelated across the width of the screen ... but this will work well for smaller mobile screens.
What would you suggest as a solution. Ideally, I like to keep the item layout to "Row - Text|Image", but make it responsive so the image / text stacks when on smaller screens. Is there any way to achieve this? I've attached a couple of images to illustrate the item layout = "Row - Text|Image".
Many thanks,
Marc
  1. https://www.lavenderandblackberry.com
Hi Marc
.j51_news figure {
flex-direction: column !important;
I've added the customer css, but unfortunately it didn't have any effect. After the CSS was added, I used FireFox's Web Developer -> Responsive Design Mode and set the width to 300px - please see the attached image. Unfortunately the article text is not readable.
Many thanks
Marc
Hi Marc
  3. # 3
Please use the same log on credentials as for the other ticket you're looking at:
ImageHover Gallery - masonry style not working
I've previously sent them to [email protected]. If you make any changes, please let me know what they are, as this is a live site.
Many thanks,
Marc
  3. # 4
Thank you Marc
Your template does not appear to have a custom CSS option. May I suggest allowing us access to your Extensions manager and we will create an override for the module to which we will add the suggested CSS directly.
  3. # 5
Actually, I see what the issue is, the CSS you originally gave was slightly incorrect for my website. I found the following worked :
.j51news figure {
Thanks for pointing me in the right direction.
Out of interest, because the text is unreadable on smaller screens, would this issue be considered as a bug and therefore be corrected in a later release of the extension?
Many thanks
Marc
  3. # 6
Hi Marc
Thank you for the update.
This is certainly an option we intend to include, that where a user can select row/column for each screen size.
  3. # 7
