1. Peters
  4. Tuesday, 06 December 2022
Hi, everyone,
I would like to use the news module. Unfortunately, my texts are displayed in white. Likewise the text when I click on read more. Unfortunately, that doesn't get me any further. I have the Ariana template.
1.Is there a newer version of the news module?
2. where can i find it
3. and where can I make settings for where the Read more text is displayed?
Best regards
Verena
For layout things, a link to the page is often needed. You can easily change that with CSS code. The J51 template template already has fields for this
In the news module you can also make certain settings. I think that you can also change the font color (Text Color) under the "General settings" tab.
[Deutsch: In dem News Modul kann man aber auch gewisse Einstellungen machen. Ich denke das man unter dem Reiter: "General settings" auch die Schriftfarbe (Text Color) ändern kann]
Hello Eumel,
thanks I know I can change the settings in the CSS. but the same posts in the same section are displayed differently. So I think it has to do with the news module. Unfortunately, I don't know where to download the latest version either. Mine is from 2020.
If you are logged in to joomla51.com with your access, then there is a menu item in your profile: "Extension download"
I have the latest version of the news module there.
For me it is 3.0.10 (date from 1.10.2021)
But if I download the latest J4 template I bought and look in the folders there, the module is there again and it has version 3.0.13!
Which version do you have?
Peters: "but the same posts in the same section are displayed differently"
A link to the problem would certainly help...
Is it possible to write you a private message?
I have the Version 3.03 and in the Extension download Area is just a module that I bought in addition. The other are in the download packeges from the Templates.
