I added some modules positions in Layla template (due to one page construction and a lot of versions of the same modules for mobile and desktop I need more the 3 in top position) in xml and index php file by copying and pasting the existing formulas and it works to a certain degree : I'am able tu publish modules in top-4, top-5 etc. positions but somehow they are not working as the originals. When I publish for examlpe 2 modules they are not 50/50, they are squeezed one to another and leavinf some space on the right side for examlpe. The other thing is the thay are not apperear in the template style editor so not possible to change anything from there too.
I have edited : templateDetails.xml, index.php and BlockHelper.php but my t new modules still look like in the attached file.
So anyway, my question would be : how to add a new module position (Top-4 for example) to the templete so it works as the original ones ?
Thank you.
Lucas
