1. mvanbergeijk
  4. Friday, 21 June 2024
I use the template Sophia. When I create a new article, the text in the status field is not visible. The correct status is selected, but the text appears to be displayed in white and is therefore not readable. Is there a solution for this?
Go to template style | General | | Typography styling | and change the Body Font Color to taste
Unfortunately this doesn't work. I set the color #6e6e6e. But it is not visible. Please help with this.
link to site please
I don't see the problem, all your articles are in the right color
body, .hornav ul ul, .hornav ul ul a, hr::before {
color: #6e6e6e;
You need to log in to create an article. I will not share credentials in this forum. See attachment for screendumps. The yellow part in the document shows not the text of the status.
I have added the following to the Custom CSS field of your template style settings which appear to have resolved the issue.
.form-select.form-select-success,
.form-select.form-select-danger {
color: #888;
Thanks for this. Unfortunately, this is not the entire solution. The statuses Published and Archived are now visible. However, the statuses Unpublished and Moved to Trash are not yet visible. Could you still look at this? Thank you in advance.
Regards,
Marco
Hi Marco
Thank you for the update. I have amended the above suggested CSS which resolves the issue for all instances.
Thanks! It works fine now.
