MENU
  1. mesquite
  4. Monday, 07 June 2021
I've installed Stella template here: https://brasseriebenaix.com/
It's not currently live because the padding between the layerslideshow module and the featured article on the homepage is massive and I need to reduce it to about 80/100 pixels maximum.
I've set you up as an administrator with the usual login details.
could you take a look for me please.
Would you have a URL to an example of the issue in the Stella template?
I've put the URL back up now.
I've had to use HAYLEY template for the time being but please feel free to administer as you wish.
Please view the website https://brasseriebenaix.com/ on both mobile and tablet to see how much padding there is between each module etc on the homepage.
The table booking module (sidecol-a) does not sit central and in portrait mode on tablet you can only view half the module.
However, the main problem is the amount of padding.
Terry
Thank you Terry
Looking at your site source, it appears you have an empty instance of the Icons module in one of the contenttop-* module positions. Disabling this module should largely resolve your issue.
Maria
Many thanks.
Terry
