1. williams
  3. Monday, 10 November 2014
I've done a few other Calibra installs before, but this one is really stumping me. I can't seem to get the mobile menu to show up. Please advise.
I'm on joomla 3.3.6.
Site is http://www.envisioneyeaustin.com/
Thank you,
Stephanie H.
EyeMotion
Thank you Steph
You appear to be using an older version of the template.
May I suggest re downloading the template and installing via your Extensions Manager to update. Only the template files will be replaced. No template style settings will be lost.
We've got a firewall to block most countries. Will whitelist Ireland and send you info to the email.
Thanks so much!
Steph
Sorry to say we are unable to access your site with the following error...
Your location (IE) has been blacklisted.
It appears Ireland is blacklisted with your server.
