1. Mol4
  4. Tuesday, 30 August 2016
on my website Levtheater I'm using the Caitlin template.
When you visit the website for the first time, the navbar on the homepage is floating in the image and you can see that the image behind it continues beneath the navbar.
When you reload the page, the navbar is at the bottom of the image and stays there.
How can I fix this so that the navbar is always at the bottom of the image behind it?
Greetings, Ton.
Hi Ton
#content-outer {
position:relative;
z-index: 1;
Hello Ciarán,
thanks! That did the trick :-)
Great!.. thank you for the udpate! :)
Hello Ciarán,
I have to open this post again because I'm getting a simular problem again.
On the test-website of my client the navbar is a few pixels above the content what results in a thin line. When I reloade the page this line is gone as it should be. I've tried the extra css you earlier suggested but that doesn't help:
#content-outer {
position:relative;
z-index: 1;
I've been trying to do a lot of different things but I can't work this out, so I'm asking for help :-)
Thanks!
To resolve we have added the following to the Custom CSS field of your templates parameters...
.vegas-slide, .vegas-slide-inner {
min-height: 590px;
Hello Ciarán,
Unfortunately this doesn't resolve the issue.
My client is viewing the testwebsite with the following specs:
Safari
Versie 10.1.2 (11603.3.8
MacOsX El Capitan
10.11.6 (15G1611)
Monitor
27-inch (5120 x 2880)
and this is how he sees it (attachment)
I have made some further changes. A bit of a shot in the dark but hopefully has resolved the issue?
Hello Ciarán,
This seems to work :-)
Can you tell me which changes you made?
Thanks!
Nice!
I changed the z-index of your content area and set an overflow hidden on your header.
Thanks!!!
After the change of the z-index, the pulldown menus doesn't work anymore.
Steven
HI Steven
Hi Ciarán
This is the URL: http://185.56.225.67/~brucknuggz/nieuwe-site/
You can see the pulldown on the homepage menu of "aanpak" does not work properly.
Steven
Hi Steven
Could you try the following instead...
#header_bg {
overflow: visible;
z-index: 4;
#container_slideshow {
overflow: hidden;
It is a little tricky this as we are unable to replicate the original issue. If the above CSS results in the original issue coming back, I think we will have to rethink the markup of the Caitlin to something more widely supported. Let me know :)
Thank you!
I think thats it!!
Hello Ciarán,
sorry to bother you again with this.
On my clients website the nvabar of the Caitlin template still is floating when you visit the page for the first time.
Because of the fact that with the first CSS exception (#content-outer) the submenu-items are not visible I've put in the second CSS exception (the #header_bg and the #container_slideshow) but somehow that seems to overrule the first CSS exception. Do you have any idea how to fix this?
Thanks again for your great help!
#content-outer {
position:relative;
z-index: 1;
#header_bg {
overflow: visible;
z-index: 4;
overflow: hidden;
Could you post a URL to an example of this issue? I can't seem to find it within this thread.
Goodmorning Ciarán,
the link to the website: Statera
Thanks!
#vegas-slideshow {
height: 714px !important;
  • 2
