1. aria
  2. Pre-Sales Question
  3. Tuesday, 14 June 2016
Hi there,
Could you tell me if the Top Navigation menu on the Nadia Menu can be fixed in place? i.e. it does not disappear when you scroll down.
Thanks,
Steen
.is-sticky #container_header {
transform: translateY(0%);
it works fine thanks.
But there are some elements that are displayed over the menu.
Please have a look at the capture
How can I correct this ?
thanks
regards
  3. # 3
#header_bg {
z-index: 10;
  3. # 4
