1. bludove
  4. Saturday, 21 January 2017
I am using the Nadia template. I would like to do a full width slideshow but I do NOT want to use the header-background slideshow. I want to set the header background to be a color and then a slideshow on top of that.
Also - the top 3 modules - on the demo they overlap the image at the top only a little bit but on mine it doesn't look at all like the demo. Basically I want it to look like the demo but with a full width slideshow.
I have a similar problem. How do you change the height of the modules? I thought they were supposed to be automatically collapsible.
1. Presuming I understand you correctly, you can place a module (slideshow) in the 'showcase' module position which is in the header area of the template. The header background can be set to a color via your templates parameters.
2. For our template demo we placed the GridGallery module in the top-1a module position. The template will then overlap the images for you.
@ronp5555
Thanks much for your quick reply. My URL is below. Need to know how to change the height size of the module. Also, just as important, need to know how to change the background color of the module. Is there a way to make the entire page one color like black? Thanks again for your help.
Forgot to insert the URL:
http://patriot-hall.com/ProductionSite/
That works. Thanks again for your help.
May I suggest placing your slideshow module in the top-1a module position, you can then set the background color (Styling tab) and remove container padding (Module Widths tab) via your templates parameters.
