1. Internetional
  3. Sunday, 09 October 2016
I have some issues with Nadia:
1. Menu item "Gewinnspiel"
You can see the arrow indicating the drop down menu. The item does not have one. But it has a sub-menu-item that is not being displayed. Is this a bug or is the arrow always being desplayed when there is a sub-menu-item?
2. Menu is being aligend to the right
I had this problem before with an other extension and I followed the steps in "Resolving Javasript errors in Joomla using 'jQuery Easy' ". But now I already have installed jQuery Easy and again the Menue is aligend to the right. Do I have to contact the developer of this extension?
3. Space between article content and navigation-menu
How can I insert a space of certain size between the content of the article and the navigation menu?
Thank you very much and regards, Marek
Hi Marek
1. Yes the indicator will appear regardless if the sub item is hidden or not. Regardless to resolve try adding the following to the Custom CSS field of your templates parameters...
.item-156.parent::after {
    display: none !important;
2. Presuming you are referring to the main menu? Have you found solution as it appears to be now split correctly?
3. To amend try adding the following to the Custom CSS field of your templates parameters...
.pull-right.article-index {
    margin-left: 40px;
Hello Ciarán,
your custom CSS works perfect as always.
No, I did not. I have tested it on FireFox, Opera, Edge and Chrome. The problem is only when I open the menu item Gallery and here open one of the categories.
Main Menu: "Service" -> "Gallerie" and here select any category
Thanks and regards, Marek
Strangely we are still unable to replicate this issue. In both Chrome and FF we are seeing your categories as follows... https://gyazo.com/98fa0eee4195095102aa4afafebe0ffc
Have you tried the following which should resolve any possible jQuery conflicts... https://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
