1. galbur
  3. Sunday, 18 September 2016
There is a tutorial to build a module postition in the header.
https://joomla51.com/tutorials/item/creating-a-new-module-position-in-the-header-area-of-your-template
It should also work for the nadia template. But i can't find this specific snippet of code
<div id ="header" class="block_holder">
in the header.php
Chris
Hi Chris
For our Nadia template your module code can be added after the following in your templates index.php (,,./templates/j51_nadia/index.php - line32)...
<div id="header" class="wrapper960">
I will try this...
Chris
Perfect!
Chris
Excellent... thank you for the update!
